Ga door naar hoofdinhoud
Sony Ericsson s710a SIM Card Replacement
  1. Sony Ericsson s710a SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 1
    • Slide the battery cover off by pushing it away from the camera side of the device.
    • This may require a good amount of force.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Ericsson s710a SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Next remove the battery
    • Lift it out of the phone using the tab on the battery (marked in the image)
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Ericsson s710a SIM Card Replacement: stap 3, afbeelding 1 van 1
    • The SIM card holder is now exposed (marked in image).
    • This will likely already have an existing SIM card in it if the phone has been previously used.
    • To open this, slide the holder upward (assuming the same orientation as in the image)
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Ericsson s710a SIM Card Replacement: stap 4, afbeelding 1 van 1
    • The holder will then hinge open.
    • You are now able to insert a new SIM card.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Ericsson s710a SIM Card Replacement: stap 5, afbeelding 1 van 1
    • Insert the new SIM card in the orientation shown.
    • This is important, as the phone will not work if the metal contacts on the card are not properly aligned with the contacts on the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Ericsson s710a SIM Card Replacement: stap 6, afbeelding 1 van 1
    • Now hinge the SIM card holder down so that it lays flat in the phone.
    • Slide the plastic holder downwards to lock it in place.
    • Now the battery and cover can be put back in place.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander
75 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 2,223
