Ga door naar hoofdinhoud
Sony Ericsson W518a Camera Lens Replacement
Wat je nodig hebt
  1. Sony Ericsson W518a Camera Lens Replacement, Faceplate: stap 1, afbeelding 1 van 1
    • Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Ericsson W518a Camera Lens Replacement: stap 2, afbeelding 1 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 2, afbeelding 2 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 2, afbeelding 3 van 3
    • Insert your plastic opening tool into the notch.
    • Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
    • When enough of the faceplate has been lifted it can be easily removed.
    • In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Ericsson W518a Camera Lens Replacement, Camera Lens: stap 3, afbeelding 1 van 1
    • Remove the four 2mm Phillips screws from the back housing of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Ericsson W518a Camera Lens Replacement: stap 4, afbeelding 1 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 4, afbeelding 2 van 3 Sony Ericsson W518a Camera Lens Replacement: stap 4, afbeelding 3 van 3
    • Insert the plastic opening tool in the notch at the top corner of the phone.
    • Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Ericsson W518a Camera Lens Replacement: stap 5, afbeelding 1 van 2 Sony Ericsson W518a Camera Lens Replacement: stap 5, afbeelding 2 van 2
    • Remove the lends by pushing the lens from the inside of the housing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
kgkramer
121 Reputatie
2 handleidingen geschreven
Cal Poly, Team 1-5, Regan SU 2012 Lid van Cal Poly, Team 1-5, Regan SU 2012
CPSU-REGAN-SU12S1G5
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 1,440
