Ga door naar hoofdinhoud
Sony DVP-SR200P Button Circuit Board Replacement
Wat je nodig hebt
  1. Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: stap 1, afbeelding 1 van 2 Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony DVP-SR200P Button Circuit Board Replacement: stap 2, afbeelding 1 van 2 Sony DVP-SR200P Button Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Slide the cover away from the front of the DVD player until it is off.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony DVP-SR200P Button Circuit Board Replacement, Processing Board: stap 3, afbeelding 1 van 1
    • Remove the blue tape from the processing board by gently pulling upward.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony DVP-SR200P Button Circuit Board Replacement: stap 4, afbeelding 1 van 2 Sony DVP-SR200P Button Circuit Board Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony DVP-SR200P Button Circuit Board Replacement: stap 5, afbeelding 1 van 1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony DVP-SR200P Button Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony DVP-SR200P Button Circuit Board Replacement, DVD Drive: stap 7, afbeelding 1 van 1
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
    Vraag FixBot
    Voeg opmerking toe
  8. Sony DVP-SR200P Button Circuit Board Replacement: stap 8, afbeelding 1 van 1
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: stap 9, afbeelding 1 van 3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: stap 9, afbeelding 2 van 3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: stap 9, afbeelding 3 van 3
    • Orient the DVD player so the button circuit board is facing you.
    • Remove the four #1 Phillips screws (silver, 3/16") from the button circuit board.
    • Three 3/16" screws from the longer button circuit board.
    • One 3/16" screw from the smaller button circuit board.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony DVP-SR200P Button Circuit Board Replacement: stap 10, afbeelding 1 van 3 Sony DVP-SR200P Button Circuit Board Replacement: stap 10, afbeelding 2 van 3 Sony DVP-SR200P Button Circuit Board Replacement: stap 10, afbeelding 3 van 3
    • Hold down the copper brace that is near the far right screw hole of the long circuit board.
    • Lift the longer button circuit board over the copper brace and out of its position.
    Vraag FixBot
    Voeg opmerking toe
  11. Sony DVP-SR200P Button Circuit Board Replacement: stap 11, afbeelding 1 van 3 Sony DVP-SR200P Button Circuit Board Replacement: stap 11, afbeelding 2 van 3 Sony DVP-SR200P Button Circuit Board Replacement: stap 11, afbeelding 3 van 3
    • Push back the black, plastic clip near the left center of the shorter button circuit board.
    • Pull the shorter button circuit board out of its position.
    Vraag FixBot
    Voeg opmerking toe
  12. Sony DVP-SR200P Button Circuit Board Replacement: stap 12, afbeelding 1 van 2 Sony DVP-SR200P Button Circuit Board Replacement: stap 12, afbeelding 2 van 2
    • Wiggle the white cord connecting the two boards out from under the plastic pieces securing the cord.
    • Lift the button circuit board out of the DVD player.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jeffrey Powell
157 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-17, Forte Winter 2013 Lid van Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 2,812
