Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W510 LCD Screen Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-W510 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 LCD Screen Replacement, Unscrew: stap 2, afbeelding 1 van 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement, Unscrew: stap 2, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 LCD Screen Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-W510 LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
kyle
424 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 1,479
