Ga door naar hoofdinhoud
Sony Cyber-shot DSC-S2100 LCD Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: stap 1, afbeelding 3 van 3
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement: stap 2, afbeelding 3 van 3
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement: stap 3, afbeelding 3 van 3
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: stap 4, afbeelding 1 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement: stap 4, afbeelding 2 van 3 Sony Cyber-shot DSC-S2100 LCD Replacement: stap 4, afbeelding 3 van 3
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: stap 5, afbeelding 1 van 1
    • Ensure the screen displayed greets you, once you reassembled your camera
Conclusie
4 andere personen hebben deze handleiding voltooid.
oldturkey03
783.943 Reputatie
119 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
33 Leden
555 handleidingen geschreven
2 opmerkingen
你在哪里?把相机给你帮我挨可以吗
Jeanne - Antwoord
请问你是在多伦多附近吗?
Jeanne - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 54
Altijd: 2,488
