Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX90V Lens Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: stap 1, afbeelding 2 van 2
    • Place the device so bottom of the camera is facing up .
    • Remove the five marked screws with a Phillips #000 screwdriver.
    • Insert the spudger where arrow marks to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 3, afbeelding 1 van 1
    • Remove the marked screw with a Phillips #000 screwdriver.
    remove screw under multi cover
    Dufour - Antwoord
  4. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 4, afbeelding 1 van 1
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  5. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 5, afbeelding 1 van 1
    • Remove the black M1.4 X 3.5 Phillips head screw.
    It’s a 1.5 mm screw
    Dufour - Antwoord
  6. Sony Cyber-shot DSC-HX90V Lens Replacement, Side cover: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: stap 7, afbeelding 2 van 2
    • Remove the small screw under the multi/USB cover.
    • Use the plastic opening tool to remove the button board.
    Remove screw under multi/usb cover
    Dufour - Antwoord
    There are 3 more screws to remove!
    Micha Helbing - Antwoord
    do you mean 3 more or 3 screws to remove if so where are they? thanks
    ColBunn -
  8. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  9. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 9, afbeelding 1 van 1
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
    Es muss vor dem lösen des Flachbandkabels vom Display die Verriegelung der Anschlussbuchse über den kleinen Hebel (schwarz oder grau) entriegelt werden. Diesen vorsichtig von hinten in Richtung Flachbandkabel hochklappen aber Vorsichtig!
    Detlef Dormann - Antwoord
    Before remove two screws :one under multi/usb socket ; onecontrol board socket
    Dufour - Antwoord
    there is a black screw behind the control board to remove. (shown under the front of the thumb in the photo.)
    sydtsai - Antwoord
  10. Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: stap 10, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: stap 10, afbeelding 2 van 2
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
    Je n'arrive pas à rebrancher ce câble et la photo ne m'aide pas. Est-ce qu'il va sous la petite barrette de la carte mère, comme je pense mais je n'arrive pas à le glisser, ou dans le pli de l'autre câble plat qui arrive à cette barrette?
    Si vous suivez encore ce fil....énorme merci d'avance.
    Agnès TOURENQ - Antwoord
  11. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 11, afbeelding 1 van 1
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
  12. Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: stap 12, afbeelding 1 van 3 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: stap 12, afbeelding 2 van 3 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: stap 12, afbeelding 3 van 3
    • Press on the lens with your finger.
    • Gently pull the lens container out of the camera.
    • Make sure all ribbon wires are unplugged.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Marin Rusinov
853 Reputatie
5 handleidingen geschreven
5 opmerkingen
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Leon - Antwoord
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
Under multi cover
Dufour - Antwoord
First at step 7
Dufour -
At step 8 remove two 2mm screws both lower sides of LCD
Dufour - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 148
Altijd: 12,552
