Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX90V Lens Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: stap 1, afbeelding 2 van 2
    • Place the device so bottom of the camera is facing up .
    • Remove the five marked screws with a Phillips #000 screwdriver.
    • Insert the spudger where arrow marks to gently remove the lower panel.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 3, afbeelding 1 van 1
    • Remove the marked screw with a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 4, afbeelding 1 van 1
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 5, afbeelding 1 van 1
    • Remove the black M1.4 X 3.5 Phillips head screw.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Cyber-shot DSC-HX90V Lens Replacement, Side cover: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: stap 7, afbeelding 2 van 2
    • Remove the small screw under the multi/USB cover.
    • Use the plastic opening tool to remove the button board.
    Vraag FixBot
    Voeg opmerking toe
  8. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 9, afbeelding 1 van 1
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: stap 10, afbeelding 1 van 2 Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: stap 10, afbeelding 2 van 2
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
    Vraag FixBot
    Voeg opmerking toe
  11. Sony Cyber-shot DSC-HX90V Lens Replacement: stap 11, afbeelding 1 van 1
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
    Vraag FixBot
    Voeg opmerking toe
  12. Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: stap 12, afbeelding 1 van 3 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: stap 12, afbeelding 2 van 3 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: stap 12, afbeelding 3 van 3
    • Press on the lens with your finger.
    • Gently pull the lens container out of the camera.
    • Make sure all ribbon wires are unplugged.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Marin Rusinov
895 Reputatie
5 handleidingen geschreven
6Gids Commentaar
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Leon - Antwoord Deel
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C - Antwoord Deel
Under multi cover
Dufour - Antwoord Deel
First at step 7
At step 8 remove two 2mm screws both lower sides of LCD
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 167
Altijd: 14,852
