Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Outer Casing: stap 1, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Outer Casing: stap 1, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Outer Casing: stap 1, afbeelding 3 van 3
    • Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
    • Note: There are two (2) screws on each side, and five (5) on the bottom edge.
  2. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool to carefully pry off the front casing.
    • Be careful to not to force the casing off. Simply move around the entire case separating where needed.
  3. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 3, afbeelding 3 van 3
    • Flip the camera over 180 degrees and similarly pry off the rear casing.
  4. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 4, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 4, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 4, afbeelding 3 van 3
    • Once the outer casings have been removed, the silver side trim should come loose from the camera.
    • Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
    • Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
  5. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 5, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 5, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 5, afbeelding 3 van 3
    • Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
    • Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
    • Grasp the top cover and gently remove it from the camera body.
  6. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Control Board: stap 6, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Control Board: stap 6, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Control Board: stap 6, afbeelding 3 van 3
    • Gently pry the tab holding the ribbon cable connecting the cameras control board to the camera sensor and battery housing.
    • The camera control board is now removed and can be replaced if faulty.
  7. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Flash Capacitor: stap 7, afbeelding 1 van 2 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement, Flash Capacitor: stap 7, afbeelding 2 van 2
    • With the camera laying with the lens up, use the plastic pry tool to gently push the two gray tabs located on the edge of the camera face.
    • Flip the camera over. With the camera laying face down, grab the gray cover on the side and gently remove it.
    • Be careful not to handle the capacitor at the contacts, or you may get shocked.
  8. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 8, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 8, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 8, afbeelding 3 van 3
    • Use the plastic pry tool to push the small round silver speaker out through the slot on the side.
    • With your hand, grab the speaker and gently remove the wires from the retaining clips.
  9. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 9, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 9, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 9, afbeelding 3 van 3
    • With the camera laying with the lens up, use the spudger tool to grab the small square piece of rubber and gently pull it out.
    • Note: Be careful not to pull on it too hard, the wires connected to it are short and could easily be pulled out or damaged.
  10. Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 10, afbeelding 1 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 10, afbeelding 2 van 3 Sony Cyber-Shot DSC-W330 Flash Capacitor Replacement: stap 10, afbeelding 3 van 3
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Place the camera facing with the lens down. Grab the black capacitor and gently remove the assembly from the holder.
    • Locate the ribbon cable connecting the capacitor to the top of the camera. Grasp the ribbon cable with your fingers, and gently pull outwards.
    • Note: You may need to gently wiggle the connector back and forth to work it out. Do not use much force to pull the cable out. If it is too difficult to remove, use the plastic pry tool to pull the connector by the tabs on the side.
    • Now the flash capacitor assembly is disconnected from the camera and can be removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sam Lewis
538 Reputatie
3 handleidingen geschreven
Clemson, Team 13-4, Benson Fall 2013 Lid van Clemson, Team 13-4, Benson Fall 2013
CLEM-BENSON-F13S13G4
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 31
Altijd: 544
