Ga door naar hoofdinhoud
Sony CPF-IP001 Subwoofer Replacement
Wat je nodig hebt
  1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: stap 1, afbeelding 1 van 2 Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: stap 1, afbeelding 2 van 2
    • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony CPF-IP001 Subwoofer Replacement: stap 2, afbeelding 1 van 2 Sony CPF-IP001 Subwoofer Replacement: stap 2, afbeelding 2 van 2
    • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
    • Using the plastic opening tool, carefully remove the circuit board.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony CPF-IP001 Subwoofer Replacement: stap 3, afbeelding 1 van 2 Sony CPF-IP001 Subwoofer Replacement: stap 3, afbeelding 2 van 2
    • Remove the first of the three wires by squeezing the clip and pulling it out.
    • After disconnecting the first wire, the two attached wires can be more easily accessed.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony CPF-IP001 Subwoofer Replacement: stap 4, afbeelding 1 van 3 Sony CPF-IP001 Subwoofer Replacement: stap 4, afbeelding 2 van 3 Sony CPF-IP001 Subwoofer Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the wire furthest to the left by squeezing the clip and pulling it out.
    • Detach the third wire by carefully using the tweezers.
    • The circuit board is now completely detached and can be set aside.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony CPF-IP001 Subwoofer Replacement: stap 5, afbeelding 1 van 2 Sony CPF-IP001 Subwoofer Replacement: stap 5, afbeelding 2 van 2
    • Remove six 8 mm Phillips #2 screws.
    • Slide the side panel with the power cord out from the housing.
    • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: stap 6, afbeelding 1 van 1
    • Remove two 8 mm Phillips #2 screws holding the side panel in place.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony CPF-IP001 Subwoofer Replacement: stap 7, afbeelding 1 van 1
    • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
    Vraag FixBot
    Voeg opmerking toe
  8. Sony CPF-IP001 Subwoofer Replacement: stap 8, afbeelding 1 van 2 Sony CPF-IP001 Subwoofer Replacement: stap 8, afbeelding 2 van 2
    • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
    • Slide the tray containing the subwoofer out of the housing.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony CPF-IP001 Subwoofer Replacement: stap 9, afbeelding 1 van 2 Sony CPF-IP001 Subwoofer Replacement: stap 9, afbeelding 2 van 2
    • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
    • Remove four 7.5 mm Phillips #2 screws.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony CPF-IP001 Subwoofer Replacement: stap 10, afbeelding 1 van 2 Sony CPF-IP001 Subwoofer Replacement: stap 10, afbeelding 2 van 2
    • The subwoofer has now been removed from the device and can be replaced.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Mike Bolton
473 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-14, Maness Spring 2015 Lid van Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 36
Altijd: 1,145
