Inleiding
Use this guide to remove and replace the speakers in the Sony CFD-8 boombox.
Wat je nodig hebt
Hold the boombox handle at an angle to access the screws behind the CD player.
Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
Gently separate the front panel from the back panel.
Remove the two connections holding the front panel to boombox.
One connection is located on the upper left hand side of the main circuit board.
The other is a large white strip slightly to the right of the cassette player.
Remove the front panel.
Use a 14cm Phillips #1 screwdriver to remove the four respective screws attaching the left and right speakers to the front panel.
