Ga door naar hoofdinhoud
Sony CFD-8 Motor Belt Replacement
Wat je nodig hebt
    1. Sony CFD-8 Motor Belt Replacement, Battery: stap 1, afbeelding 1 van 3 Sony CFD-8 Motor Belt Replacement, Battery: stap 1, afbeelding 2 van 3 Sony CFD-8 Motor Belt Replacement, Battery: stap 1, afbeelding 3 van 3
      • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
      • Be sure to unplug the boombox from the wall before attempting to open it for repair.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony CFD-8 Motor Belt Replacement: stap 2, afbeelding 1 van 2 Sony CFD-8 Motor Belt Replacement: stap 2, afbeelding 2 van 2
      • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
      • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony CFD-8 Motor Belt Replacement, Front Panel: stap 3, afbeelding 1 van 3 Sony CFD-8 Motor Belt Replacement, Front Panel: stap 3, afbeelding 2 van 3 Sony CFD-8 Motor Belt Replacement, Front Panel: stap 3, afbeelding 3 van 3
      • Hold the boombox handle at an angle to access the screws behind the CD player.
      • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony CFD-8 Motor Belt Replacement: stap 4, afbeelding 1 van 2 Sony CFD-8 Motor Belt Replacement: stap 4, afbeelding 2 van 2
      • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
      • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony CFD-8 Motor Belt Replacement: stap 5, afbeelding 1 van 3 Sony CFD-8 Motor Belt Replacement: stap 5, afbeelding 2 van 3 Sony CFD-8 Motor Belt Replacement: stap 5, afbeelding 3 van 3
      • Gently separate the front panel from the back panel.
      • Remove the two connections holding the front panel to boombox.
      • One connection is located on the upper left hand side of the main circuit board.
      • The other is a large white strip slightly to the right of the cassette player.
      • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
      • Remove the front panel.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony CFD-8 Motor Belt Replacement, Remove Gear Assembly: stap 6, afbeelding 1 van 1
      • Unscrew the 3x12 screws circled in the photo using a #1 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony CFD-8 Motor Belt Replacement, Disconnect Wires: stap 7, afbeelding 1 van 1
      • Carefully disconnect the wire connection by pulling at its base.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony CFD-8 Motor Belt Replacement, Remove Motor: stap 8, afbeelding 1 van 3 Sony CFD-8 Motor Belt Replacement, Remove Motor: stap 8, afbeelding 2 van 3 Sony CFD-8 Motor Belt Replacement, Remove Motor: stap 8, afbeelding 3 van 3
      • Unscrew the 5mm screw shown in the photo.
      • Note the small latch on the side of assembly as you remove the motor.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: stap 9, afbeelding 1 van 2 Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: stap 9, afbeelding 2 van 2
      • Remove the motor belt from its axle.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Wil Gilbreath
205 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-38, Amido Fall 2014 Lid van Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Leden
21 handleidingen geschreven
4Gids Commentaar
need belt for cassette replace
joe jefferson - Antwoord Deel
need the belt for the cassette player
First, be sure to have a #1 pt screwdriver with at least a 5” shaft(not counting the handle) length. Second, pay attention to where the screws under the handle are located. Third, mark the top of the connectors with a sharpie or such instrument to be sure you are replacing the connector in the correct position.
Don Gunkel - Antwoord Deel
Here's some information about the belts needed, which may be especially useful if your old belts have turned to goo like mine! Two identical belts are needed: the Sony part number is 3-362-989-01, and generic names appear to include SBO5.2 and SCY5.2. It's a square belt with 1 mm thickness and an inside diameter of 5.2 inches. I found that the most economical way to purchase these was to get a bulk bag of 1 mm square belts of mixed length.
SandStone - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 109
Altijd: 14,951
