Inleiding
The Wifi-Module allows the Sony BDP-S3500 Blu Ray player to connect wirelessly to the internet. This guide will show you how to replace it safely without damaging the other components.
Be sure to review the troubleshooting guide, as most of the time the problems are due malfunctioning software rather than it being a hardware issue.
Wat je nodig hebt
Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
Keep the back side up and facing towards you.
Carefully disconnect the blue ribbon connecting the port board and motherboard.
Remove the white ribbon cable connecting the Wi-Fi module to the motherboard by gently pulling it out.
