Ga door naar hoofdinhoud
Sony BDP-S3500 Port Board Replacement
Wat je nodig hebt
  1. Sony BDP-S3500 Port Board Replacement, Front Panel: stap 1, afbeelding 1 van 2 Sony BDP-S3500 Port Board Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Port Board Replacement: stap 2, afbeelding 1 van 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Port Board Replacement: stap 3, afbeelding 1 van 2 Sony BDP-S3500 Port Board Replacement: stap 3, afbeelding 2 van 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Port Board Replacement, Port Board: stap 4, afbeelding 1 van 2 Sony BDP-S3500 Port Board Replacement, Port Board: stap 4, afbeelding 2 van 2
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
  5. Sony BDP-S3500 Port Board Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
  6. Sony BDP-S3500 Port Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the port board from the device.
Conclusie
Megh Ladumor
100 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 279
