Ga door naar hoofdinhoud
Sony BDP-S3500 Motherboard Replacement
Wat je nodig hebt
  1. Sony BDP-S3500 Motherboard Replacement, Front Panel: stap 1, afbeelding 1 van 2 Sony BDP-S3500 Motherboard Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Motherboard Replacement: stap 3, afbeelding 1 van 2 Sony BDP-S3500 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Motherboard Replacement, Disk Drive: stap 4, afbeelding 1 van 2 Sony BDP-S3500 Motherboard Replacement, Disk Drive: stap 4, afbeelding 2 van 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Motherboard Replacement: stap 5, afbeelding 1 van 2 Sony BDP-S3500 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Motherboard Replacement: stap 6, afbeelding 1 van 2 Sony BDP-S3500 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift and slide the disk drive out of the casing.
  7. Sony BDP-S3500 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 Sony BDP-S3500 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Remove the ribbon cables by holding onto the cable and gently pulling straight up.
  8. Sony BDP-S3500 Motherboard Replacement: stap 8, afbeelding 1 van 3 Sony BDP-S3500 Motherboard Replacement: stap 8, afbeelding 2 van 3 Sony BDP-S3500 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Use the Phillips #2 screwdriver to remove three 9mm screws securing the motherboard to the case.
    • Remove one 5.5mm Phillips #2 from the back of the case near the ports.
  9. Sony BDP-S3500 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Slide the motherboard away from the back of the case and then lift up to remove.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael Meissner
220 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 484
