Inleiding
If you are having issues with overheating it is most likely being caused by a faulty fan. In this guide we will open the player up by removing the connecting screws and then removed the faulty fan so it can be replaced for a new one.
Wat je nodig hebt
Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
Don't forget, there are two more 12mm screws on the other side as well.
First we need to unscrew the fan from before we can remove it.
Remove both copper colored 10mm screws with a #2 phillips screwdriver.
As you remove the second screw, pull the fan inward to remove it from the remainder of the case. It should now only be connected to the case through a cable attached to the circuit board.
2Gids Commentaar
We're can i get a replacement fan for my Blu- ray player model BDV-E4100. HEEEEELP PLEASE.
Where can I get a replacement fan for my blue-ray player.
