Ga door naar hoofdinhoud
Sony BDP-BX520 Disc Tray Replacement
Wat je nodig hebt
    1. Sony BDP-BX520 Disc Tray Replacement, Disc Tray Cover: stap 1, afbeelding 1 van 1
      • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
      • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony BDP-BX520 Disc Tray Replacement: stap 2, afbeelding 1 van 1
      • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony BDP-BX520 Disc Tray Replacement: stap 3, afbeelding 1 van 1
      • Close the disc tray, then power off and unplug the Blu-Ray player.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony BDP-BX520 Disc Tray Replacement, Top Case: stap 4, afbeelding 1 van 1
      • Locate the three 8 mm screws on the back of the Blu-Ray player.
      • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony BDP-BX520 Disc Tray Replacement: stap 5, afbeelding 1 van 2 Sony BDP-BX520 Disc Tray Replacement: stap 5, afbeelding 2 van 2
      • Gently pull the top case back to remove it from the Blu-Ray player.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony BDP-BX520 Disc Tray Replacement, Front Panel: stap 6, afbeelding 1 van 1
      • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
      • Lifting these clips may require you to hold one clip open while you move on to the next clip.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony BDP-BX520 Disc Tray Replacement: stap 7, afbeelding 1 van 1
      • Flip device over so the bottom faces you.
      • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony BDP-BX520 Disc Tray Replacement: stap 8, afbeelding 1 van 1
      • Lift the clip on the opposite side of the device with the nylon or metal spudger.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony BDP-BX520 Disc Tray Replacement: stap 9, afbeelding 1 van 2 Sony BDP-BX520 Disc Tray Replacement: stap 9, afbeelding 2 van 2
      • Grasp the front case firmly and lift from the rest of the device.
      • Lifting may require some force.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony BDP-BX520 Disc Tray Replacement, Disc Tray: stap 10, afbeelding 1 van 2 Sony BDP-BX520 Disc Tray Replacement, Disc Tray: stap 10, afbeelding 2 van 2
      • Using a Phillips #2 screwdriver, remove the two silver 8 mm screws on the right side of the disk tray .
      Vraag FixBot
      Voeg opmerking toe
    2. Sony BDP-BX520 Disc Tray Replacement: stap 11, afbeelding 1 van 2 Sony BDP-BX520 Disc Tray Replacement: stap 11, afbeelding 2 van 2
      • Pull the medium-sized 9 pin ribbon cable out of its connector on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony BDP-BX520 Disc Tray Replacement: stap 12, afbeelding 1 van 3 Sony BDP-BX520 Disc Tray Replacement: stap 12, afbeelding 2 van 3 Sony BDP-BX520 Disc Tray Replacement: stap 12, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Using tweezers, lift up the tab of the large 45 pin connector on the motherboard.
      • Pull the large 45 pin ribbon cable out of its connector.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony BDP-BX520 Disc Tray Replacement: stap 13, afbeelding 1 van 2 Sony BDP-BX520 Disc Tray Replacement: stap 13, afbeelding 2 van 2
      • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony BDP-BX520 Disc Tray Replacement: stap 14, afbeelding 1 van 2 Sony BDP-BX520 Disc Tray Replacement: stap 14, afbeelding 2 van 2
      • Slide the disk tray out from under the tabs on the case holding it down while lifting it out of the case.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Gregory Pellegrino
405 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-41, Amido Winter 2015 Lid van Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Leden
56 handleidingen geschreven
3Gids Commentaar
Thanks, this helped a lot. I still cant get the DVD drawer to eject with the eject button. The power light will not turn off.
tomcerecedes - Antwoord Deel
Thank you thank you thank you. I spent an hour on the phone with Sony “technical support “ and was told nothing could be done except to send it off for servicing. This worked PERFECTLY!!!! THANKS AGAIN ?
Susan Brown - Antwoord Deel
Cómo retiro la charola del disco
Anuar - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 8,103
