Ga door naar hoofdinhoud
Sony Alpha NEX-6 Lens Replacement
    1. Sony Alpha NEX-6 Lens Replacement, Finding the Release Button: stap 1, afbeelding 1 van 1
      • Turn the camera with the lens facing up.
      • Find the lens release button - located along the side of the silver lens mount.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Alpha NEX-6 Lens Replacement, Removing the Lens: stap 2, afbeelding 1 van 2 Sony Alpha NEX-6 Lens Replacement, Removing the Lens: stap 2, afbeelding 2 van 2
      • Press and hold the lens release button while rotating the lens counterclockwise.
      • Lift the lens when it is no longer attached to the camera.
      • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
      • Insert the lens and rotate it clockwise until it is locked in place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
The procedure to disassemble this lens is different from reassembly. This guide encompasses both processes.
Clayton Dale
1.067 Reputatie
7 handleidingen geschreven
USF Tampa, Team 11-2, Blackwell Winter 2015 Lid van USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Leden
63 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 3,199
