Ga door naar hoofdinhoud
Sony Alpha NEX-6 LCD Screen Replacement
Wat je nodig hebt
    1. Sony Alpha NEX-6 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Alpha NEX-6 LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Alpha NEX-6 LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony Alpha NEX-6 LCD Screen Replacement, Removing back screws: stap 4, afbeelding 1 van 1
      • Remove the two 1.0 mm Phillips #00 screws from back of the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Alpha NEX-6 LCD Screen Replacement, Removing bottom screws: stap 5, afbeelding 1 van 1
      • Remove the two 1.5 mm Phillips #00 screws from the bottom of the screen mount assembly.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Alpha NEX-6 LCD Screen Replacement, Back cover: stap 6, afbeelding 1 van 2 Sony Alpha NEX-6 LCD Screen Replacement, Back cover: stap 6, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Using a plastic opening tool pry off the back cover from the screen assembly.
      • Remove back cover by lifting it away from the screen using tweezers.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: stap 7, afbeelding 1 van 3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: stap 7, afbeelding 2 van 3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: stap 7, afbeelding 3 van 3
      • Release the ribbon cable by lifting the black locking latch with the plastic opening tool.
      • Pry out the ribbon cable by carefully sliding it out of the connection slot using a spudger.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony Alpha NEX-6 LCD Screen Replacement, Upper plastic separator: stap 8, afbeelding 1 van 1
      • Lift and slide out the upper black plastic separator using tweezers.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: stap 9, afbeelding 1 van 3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: stap 9, afbeelding 2 van 3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: stap 9, afbeelding 3 van 3
      • Lift and remove the lower black plastic separator using tweezers.
      • Using the pointy side of a spudger push in the screen lock button release it.
      • The screen lock button can now be removed.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: stap 10, afbeelding 1 van 3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: stap 10, afbeelding 2 van 3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: stap 10, afbeelding 3 van 3
      • Using the flat end of the spudger, push on the black nylon sheet glued to the metallic frame to peel it of.
      • Apply force from different spots to avoid tearing the sheet.
      • Remove the black nylon sheet using tweezers.
      Vraag FixBot
      Voeg opmerking toe
    8. Sony Alpha NEX-6 LCD Screen Replacement, Screen Removal: stap 11, afbeelding 1 van 1
      • Gently wiggle the screen loose and remove it from the mount.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Clayton Dale
1.067 Reputatie
7 handleidingen geschreven
USF Tampa, Team 11-2, Blackwell Winter 2015 Lid van USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Leden
63 handleidingen geschreven
2Gids Commentaar
Thanks a million! Great guide and saved me $250 sending it back in.
Al Weiner - Antwoord Deel
Hi - I am trying to fix one of these -- and the guy I bought it from pulled off and lost the black locking latch from the ribbon cable rather than just lifting it -- I can get the LCD screen to light but can't keep it on very long -- I bought another one of these internal cables with the black locking latch. Do you think I can pop that one off and move it to this one? Or do you have any source of instructions how to replace that cable?
Cheers and thanks for this!
PS -- If anyone is just trying to get rid of the dreaded bubbles in the screen saver that plagues these NEX cameras -- it does just peal off -- see youtubes,,,
Harvey Cat - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 52
Altijd: 8,252
