Ga door naar hoofdinhoud
Sony Alpha A3000 Battery Replacement
    1. Sony Alpha A3000 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • The battery compartment is located on the bottom of the camera as shown. To access the battery slide the compartment switch from LOCK to OPEN.
      • Before operating on device, ensure that the camera is powered off and the surface of operation is clean and free of dirt or other obstructions.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Alpha A3000 Battery Replacement: stap 2, afbeelding 1 van 1
      • Push back the blue tab releasing the battery which should spring forth on its own.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Alpha A3000 Battery Replacement: stap 3, afbeelding 1 van 1
      • To insert replacement, depress the blue tab again inserting the battery as shown until the blue tab springs back into place. Ensure battery is secure, close the battery compartment and return the latch to the LOCK position.
      • The replacement battery must meet specifications declared by Sony.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Junior Recinos
245 Reputatie
1 Handleiding geschreven
USF Tampa, Team 4-4, Meier Fall 2015 Lid van USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 40
Altijd: 2,836
