Ga door naar hoofdinhoud
Sony AZ1VR LCD Side Display Replacement
Wat je nodig hebt
  1. Sony AZ1VR LCD Side Display Replacement, LCD Side Display: stap 1, afbeelding 1 van 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: stap 1, afbeelding 2 van 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: stap 1, afbeelding 3 van 3
    • Remove the two screws on the bottom of the camera.
    • Remove the screw inside the battery door.
    • Once these are removed, slide the door out, and the small piece of plastic with the door.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony AZ1VR LCD Side Display Replacement: stap 2, afbeelding 1 van 3 Sony AZ1VR LCD Side Display Replacement: stap 2, afbeelding 2 van 3 Sony AZ1VR LCD Side Display Replacement: stap 2, afbeelding 3 van 3
    • Grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
    • You'll see a screw on the top of the device, towards the front, remove this screw.
    • Pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony AZ1VR LCD Side Display Replacement: stap 3, afbeelding 1 van 3 Sony AZ1VR LCD Side Display Replacement: stap 3, afbeelding 2 van 3 Sony AZ1VR LCD Side Display Replacement: stap 3, afbeelding 3 van 3
    • Remove the screws connected to the silver metal plate.
    • Remove the plate by pulling the back up and pushing it towards the front.
    • Remove the screw directly above the LCD display.
    • Pull the plastic up gently, it will be connected by cables on the bottom.
    • Disconnect the cable going to the LCD display.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Michael Martin
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G5, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G5, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G5
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 355
