Inleiding
The SD card reader is responsible for exchanging data between the camera and memory card. If you have trouble storing photos on the camera or receive alerts stating that no SD card is inserted (when one is inserted), the SD card reader may be faulty. This guide will show you how to replace the SD card slot, which is located next to the battery of the Sony a6500 camera. The tools required for this guide are opening tools, JIS 0 screwdriver, JIS 00 screwdriver, JIS 000 screwdriver, tweezers, and spudger.
Wat je nodig hebt
From the top of the camera remove one 4mm JIS 00 screw.
Remove one 5mm JIS 00 screw and the plastic bushing around it.
Remove the viewfinder's protective cover.
Remove two 2.5mm JIS 00 screws from the left side and bottom of the copper shielding.
Remove two 2mm JIS 000 screws from the right side of the copper shielding.
Pull the entire copper shielding piece off.
Unplug the small ribbon located underneath the ON/OFF button and detach the button assembly from the camera.
