Ga door naar hoofdinhoud
Sony α6500 LCD Screen Replacement
Wat je nodig hebt
  1. Sony α6500 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Sony α6500 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Sony α6500 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the released battery from the compartment.
  5. Sony α6500 LCD Screen Replacement, LCD Screen: stap 5, afbeelding 1 van 3 Sony α6500 LCD Screen Replacement, LCD Screen: stap 5, afbeelding 2 van 3 Sony α6500 LCD Screen Replacement, LCD Screen: stap 5, afbeelding 3 van 3
    • To access the LCD assembly we need to remove the screws attaching its hinge to the camera body.
    • Remove four 3mm JIS 000 screws.
    • Remove one 3mm JIS 00 screw.
    • After dismounting the screen hinge be careful to not tear the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 LCD Screen Replacement: stap 6, afbeelding 1 van 2 Sony α6500 LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove the screen hinge from the camera.
    • Be careful to not tear the black flat cable connecting the lcd screen to the main body of the camera. This particular camera's cable has been cut for demonstration purposes.
  7. Sony α6500 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Flip the LCD screen up.
    • Remove two 2mm JIS 000 screws on the bottom edge.
  8. Sony α6500 LCD Screen Replacement: stap 8, afbeelding 1 van 2 Sony α6500 LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Flip the LCD screen down to access the back side.
    • Remove two 2mm JIS 000 screws to release the back panel of the screen.
  9. Sony α6500 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Sony α6500 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Use the opening tool to pry open the back panel.
    • Remove the black plastic spacer laying on top of the circuit board.
  10. Sony α6500 LCD Screen Replacement: stap 10, afbeelding 1 van 2 Sony α6500 LCD Screen Replacement: stap 10, afbeelding 2 van 2
    • Carefully unplug the three wire ribbons from the circuit board with tweezers.
    • Likely you will need to wiggle the ribbons for a while before they come loose.
    • The ribbons can rip very easily, grasp the black plastic with the tweezers, on the two top ribbons, not the orange wires.
  11. Sony α6500 LCD Screen Replacement: stap 11, afbeelding 1 van 3 Sony α6500 LCD Screen Replacement: stap 11, afbeelding 2 van 3 Sony α6500 LCD Screen Replacement: stap 11, afbeelding 3 van 3
    • Slide the spudger around all sides of the screen's plastic frame, gently breaking the adhesive.
    • Remove the screen from the camera by prying it out.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Micah Fitzgerald
624 Reputatie
2 handleidingen geschreven
Cal Poly, Team S11-G5, Regan Fall 2019 Lid van Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Leden
14 handleidingen geschreven
2 opmerkingen
Hello, do you have an updated link with a currently available lcd screen replacement part?
JRS - Joe’s Random Stuff - Antwoord
Can I use an a6500 screen to replace an a6600 screen? Are they interchangeable?
Connor Snyder - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 56
Altijd: 2,646
