Ga door naar hoofdinhoud
Sonos Playbase Optical Audio Port Replacement
Wat je nodig hebt
    1. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: stap 1, afbeelding 1 van 3 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: stap 1, afbeelding 2 van 3 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: stap 1, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Pro Tech Toolkit
      $79.95
      • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
      • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
      • Melt the adhesive with an iOpener for ease of opening
      • Use a Metal Spudger if the plastic spudgers do not work.
      • Take care to avoid damaging the plastic or the device if using a metal spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. Sonos Playbase Optical Audio Port Replacement: stap 2, afbeelding 1 van 2 Sonos Playbase Optical Audio Port Replacement: stap 2, afbeelding 2 van 2
      Pro Tech Toolkit
      $79.95
      • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
      • Remove the seven 44mm T-20 screws by turning counter-clockwise.
      • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
      • Record where each screw belongs for easier reassembly.
      Vraag FixBot
      Voeg opmerking toe
    3. Sonos Playbase Optical Audio Port Replacement: stap 3, afbeelding 1 van 2 Sonos Playbase Optical Audio Port Replacement: stap 3, afbeelding 2 van 2
      Pro Tech Toolkit
      $79.95
      • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
      • Use a metal spudger if plastic openers do not work.
      Vraag FixBot
      Voeg opmerking toe
    1. Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: stap 4, afbeelding 1 van 2 Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: stap 4, afbeelding 2 van 2
      • Unplug the optical audio port from the main circuit board by pinching the white clip and pulling upward.
      Vraag FixBot
      Voeg opmerking toe
    2. Sonos Playbase Optical Audio Port Replacement: stap 5, afbeelding 1 van 2 Sonos Playbase Optical Audio Port Replacement: stap 5, afbeelding 2 van 2
      • Remove the three 38mm T-55 screws preventing you from removing the Optical Audio Port screws by turning them counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    3. Sonos Playbase Optical Audio Port Replacement: stap 6, afbeelding 1 van 2 Sonos Playbase Optical Audio Port Replacement: stap 6, afbeelding 2 van 2
      Pro Tech Toolkit
      $79.95
      • Remove the two 18mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    4. Sonos Playbase Optical Audio Port Replacement: stap 7, afbeelding 1 van 2 Sonos Playbase Optical Audio Port Replacement: stap 7, afbeelding 2 van 2
      • Remove the Optical Audio Port from the housing by pinching the sides and pulling outward.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
James Andrews
423 Reputatie
4 handleidingen geschreven
Cal Poly, Team S17-G2, White Fall 2018 Lid van Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Leden
24 handleidingen geschreven
1Gids Commentaar
Thank you for this guide, but any idea where to purchase a replacement optical audio port from?
donovanclarkson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 2,968
