Ga door naar hoofdinhoud
Sonos Playbase IR Reciver Replacement
Wat je nodig hebt
    1. Sonos Playbase IR Reciver Replacement, Bottom Panel: stap 1, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement, Bottom Panel: stap 1, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement, Bottom Panel: stap 1, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Pro Tech Toolkit
      $79.95
      • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
      • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
      • Melt the adhesive with an iOpener for ease of opening
      • Use a Metal Spudger if the plastic spudgers do not work.
      • Take care to avoid damaging the plastic or the device if using a metal spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. Sonos Playbase IR Reciver Replacement: stap 2, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 2, afbeelding 2 van 2
      Pro Tech Toolkit
      $79.95
      • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
      • Remove the seven 44mm T-20 screws by turning counter-clockwise.
      • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
      • Record where each screw belongs for easier reassembly.
      Vraag FixBot
      Voeg opmerking toe
    3. Sonos Playbase IR Reciver Replacement: stap 3, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 3, afbeelding 2 van 2
      Pro Tech Toolkit
      $79.95
      • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
      • Use a metal spudger if plastic openers do not work.
      Vraag FixBot
      Voeg opmerking toe
    1. Sonos Playbase IR Reciver Replacement, Main Speaker Array: stap 4, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement, Main Speaker Array: stap 4, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    2. Sonos Playbase IR Reciver Replacement: stap 5, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 5, afbeelding 2 van 2
      • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
      • See Recognizing & Disconnecting Cable Connectors for more information.
      Vraag FixBot
      Voeg opmerking toe
    3. Sonos Playbase IR Reciver Replacement: stap 6, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement: stap 6, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement: stap 6, afbeelding 3 van 3
      Pro Tech Toolkit
      $79.95
      • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
      Vraag FixBot
      Voeg opmerking toe
    4. Sonos Playbase IR Reciver Replacement: stap 7, afbeelding 1 van 1
      • Remove the main speaker array by gripping it on both sides and pulling it out.
      • The array may require a significant amount of force to remove.
      • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
      • Do not to yank the array out too suddenly or too far as this may damage the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Sonos Playbase IR Reciver Replacement: stap 8, afbeelding 1 van 1
      • Prop the removed main speaker array up on top of the main circuit board.
      Vraag FixBot
      Voeg opmerking toe
    1. Sonos Playbase IR Reciver Replacement, IR Receiver: stap 9, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement, IR Receiver: stap 9, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement, IR Receiver: stap 9, afbeelding 3 van 3
      Pro Tech Toolkit
      $79.95
      • Lift the main speaker array to reveal the IR receiver underneath.
      • Remove the three 11 mm T-5 screws by turning counter-clockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. Sonos Playbase IR Reciver Replacement: stap 10, afbeelding 1 van 3 Sonos Playbase IR Reciver Replacement: stap 10, afbeelding 2 van 3 Sonos Playbase IR Reciver Replacement: stap 10, afbeelding 3 van 3
      Vraag FixBot
      Voeg opmerking toe
    3. Sonos Playbase IR Reciver Replacement: stap 11, afbeelding 1 van 2 Sonos Playbase IR Reciver Replacement: stap 11, afbeelding 2 van 2
      • Remove the IR receiver by grasping it with two fingers and pulling up.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
George Slivka
341 Reputatie
3 handleidingen geschreven
Cal Poly, Team S17-G2, White Fall 2018 Lid van Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 1,752
