Ga door naar hoofdinhoud
Sonos One Control Panel & Microphone Replacement
Wat je nodig hebt
    1. Sonos One Control Panel & Microphone Replacement, Protective Cover: stap 1, afbeelding 1 van 3 Sonos One Control Panel & Microphone Replacement, Protective Cover: stap 1, afbeelding 2 van 3 Sonos One Control Panel & Microphone Replacement, Protective Cover: stap 1, afbeelding 3 van 3
      • Disconnect all power cords.
      • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
      • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
      Vraag FixBot
      Voeg opmerking toe
    2. Sonos One Control Panel & Microphone Replacement: stap 2, afbeelding 1 van 3 Sonos One Control Panel & Microphone Replacement: stap 2, afbeelding 2 van 3 Sonos One Control Panel & Microphone Replacement: stap 2, afbeelding 3 van 3
      • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
      Vraag FixBot
      Voeg opmerking toe
    3. Sonos One Control Panel & Microphone Replacement: stap 3, afbeelding 1 van 2 Sonos One Control Panel & Microphone Replacement: stap 3, afbeelding 2 van 2
      • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. Sonos One Control Panel & Microphone Replacement: stap 4, afbeelding 1 van 3 Sonos One Control Panel & Microphone Replacement: stap 4, afbeelding 2 van 3 Sonos One Control Panel & Microphone Replacement: stap 4, afbeelding 3 van 3
      • The protective cover clip is very thin and deforms easily.
      • Remove the single 8mm Torx T10 screw and protective cover clip.
      Vraag FixBot
      Voeg opmerking toe
    5. Sonos One Control Panel & Microphone Replacement: stap 5, afbeelding 1 van 2 Sonos One Control Panel & Microphone Replacement: stap 5, afbeelding 2 van 2
      • Slide the protective cover upwards to remove.
      Vraag FixBot
      Voeg opmerking toe
    1. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: stap 6, afbeelding 1 van 3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: stap 6, afbeelding 2 van 3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: stap 6, afbeelding 3 van 3
      • Use the pointed end of a spudger to remove the covers that hide the screws.
      • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Sonos One Control Panel & Microphone Replacement: stap 7, afbeelding 1 van 2 Sonos One Control Panel & Microphone Replacement: stap 7, afbeelding 2 van 2
      • With the front of the unit facing you, lift the control panel up using your thumbs.
      • There's a ribbon cable attaching the control panel to the speaker so work slowly.
      Vraag FixBot
      Voeg opmerking toe
    3. Sonos One Control Panel & Microphone Replacement: stap 8, afbeelding 1 van 3 Sonos One Control Panel & Microphone Replacement: stap 8, afbeelding 2 van 3 Sonos One Control Panel & Microphone Replacement: stap 8, afbeelding 3 van 3
      • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
      • Pull the control panel ribbon cable out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    4. Sonos One Control Panel & Microphone Replacement: stap 9, afbeelding 1 van 2 Sonos One Control Panel & Microphone Replacement: stap 9, afbeelding 2 van 2
      • Pull the control panel away from the speaker to separate.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Marcus Glowa
1.134 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G1, Nance Spring 2018 Lid van USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Leden
24 handleidingen geschreven
1Gids Commentaar
where can I buy a replacement control panel?
Chris Myers - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 91
Altijd: 8,570
