Inleiding
With just the push of a button, the charging indicator button to tell you the power status of your Rocsta Solio charger. In this guide, we will show you how to replace the charging indicator button if it no longer functions properly.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Wat je nodig hebt
Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
Unscrew the 5.66 mm screws attaching the circuit board to the case.
