Ga door naar hoofdinhoud
Solio Rocsta Charging Cable Replacement
Wat je nodig hebt
  1. Solio Rocsta Charging Cable Replacement, Charging Cable: stap 1, afbeelding 1 van 2 Solio Rocsta Charging Cable Replacement, Charging Cable: stap 1, afbeelding 2 van 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Cable Replacement: stap 2, afbeelding 1 van 2 Solio Rocsta Charging Cable Replacement: stap 2, afbeelding 2 van 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire.
  3. Solio Rocsta Charging Cable Replacement: stap 3, afbeelding 1 van 1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Cable Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  5. Solio Rocsta Charging Cable Replacement: stap 5, afbeelding 1 van 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Cable Replacement: stap 6, afbeelding 1 van 1
    • With a Soldering Iron, desolder the four cables that connect the charging cable to the circuit board.
    • The power cable is a series of four cables. Make note of each cable placement for easy resoldering.
    • For more information on how to solder and desolder connections, please visit this guide.
Conclusie
David Vazquez
577 Reputatie
5 handleidingen geschreven
USF Tampa, Team S13-G13, Cagle Fall 2017 Lid van USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 193
