Ga door naar hoofdinhoud
Solio CLASSIC2 Battery Replacement
Wat je nodig hebt
    1. Solio CLASSIC2 Battery Replacement, Disconnecting the Battery: stap 1, afbeelding 1 van 1
      • Turn off the device by pressing on the clear power button behind the device.
      • To make sure that it is off, make sure the button is not flashing green.
      Vraag FixBot
      Voeg opmerking toe
    2. Solio CLASSIC2 Battery Replacement: stap 2, afbeelding 1 van 1
      • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
      Vraag FixBot
      Voeg opmerking toe
    3. Solio CLASSIC2 Battery Replacement: stap 3, afbeelding 1 van 3 Solio CLASSIC2 Battery Replacement: stap 3, afbeelding 2 van 3 Solio CLASSIC2 Battery Replacement: stap 3, afbeelding 3 van 3
      • Using the plastic opening tools, gently pry open the side of the large panel.
      • Keeping the tool in, slowly slide the tool along the side of the panel.
      Vraag FixBot
      Voeg opmerking toe
    4. Solio CLASSIC2 Battery Replacement: stap 4, afbeelding 1 van 2 Solio CLASSIC2 Battery Replacement: stap 4, afbeelding 2 van 2
      • Rotate the device 180 degrees.
      • Make sure the opening on other side of the device does not snap closed.
      • Gently slide the plastic opening tool along the side of the panel.
      Vraag FixBot
      Voeg opmerking toe
    5. Solio CLASSIC2 Battery Replacement: stap 5, afbeelding 1 van 2 Solio CLASSIC2 Battery Replacement: stap 5, afbeelding 2 van 2
      • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
      • Using both hands, slowly pull apart the back panel from the rest of the device.
      • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
      Vraag FixBot
      Voeg opmerking toe
    6. Solio CLASSIC2 Battery Replacement: stap 6, afbeelding 1 van 2 Solio CLASSIC2 Battery Replacement: stap 6, afbeelding 2 van 2
      • Softly pinch the red and blue wires close to the white connector.
      • To pull the wires out, wiggle them back and forth until the connector is fully out.
      Vraag FixBot
      Voeg opmerking toe
    1. Solio CLASSIC2 Battery Replacement, Circuit Board: stap 7, afbeelding 1 van 1
      • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Solio CLASSIC2 Battery Replacement: stap 8, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
      • Gently lift the circuit board out of the device using tweezers.
      Vraag FixBot
      Voeg opmerking toe
    1. Solio CLASSIC2 Battery Replacement, Battery: stap 9, afbeelding 1 van 1
      • Remove the two 2mm screws from the battery case.
      Vraag FixBot
      Voeg opmerking toe
    2. Solio CLASSIC2 Battery Replacement: stap 10, afbeelding 1 van 1
      • Gently pull up the battery case out of the tabs and pull the case out.
      Vraag FixBot
      Voeg opmerking toe
    3. Solio CLASSIC2 Battery Replacement: stap 11, afbeelding 1 van 1
      • Gently lift up the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Johnny Tran
311 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-28, Amido Fall 2013 Lid van Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 45
Altijd: 1,782
