Ga door naar hoofdinhoud
Sol Republic Deck Play/Pause Button Replacement
Wat je nodig hebt
    1. Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: stap 1, afbeelding 1 van 3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: stap 1, afbeelding 2 van 3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: stap 1, afbeelding 3 van 3
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Pry the front face plate from the bottom half of the speaker by inserting the spudger edge into the the middle groove.
      • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
      Vraag FixBot
      Voeg opmerking toe
    2. Sol Republic Deck Play/Pause Button Replacement: stap 2, afbeelding 1 van 1
      • On the front face of the device, locate the green plastic Motorola (M) button that controls the playing and pausing of music.
      Vraag FixBot
      Voeg opmerking toe
    3. Sol Republic Deck Play/Pause Button Replacement: stap 3, afbeelding 1 van 1
      • Using your finger, push the M button towards the inside of the device.
      Vraag FixBot
      Voeg opmerking toe
    4. Sol Republic Deck Play/Pause Button Replacement: stap 4, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using the tweezers, grab the button as it comes through and pull it carefully off of the pegs.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mary Place
170 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 1,179
