Inleiding
Traction pads are used to give you extra grip when you have one foot out of the bindings. This guide is about detaching and attaching traction pads.
Wat je nodig hebt
Peel the back off of the new traction pad to reveal the adhesive.
When placed, the traction pad should be about an inch away from the rear binding.
To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
Give the adhesive a minimum of 12 hours to dry before use.
