Ga door naar hoofdinhoud
Smart Parts Ion Bolt Replacement
Wat je nodig hebt
    1. Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: stap 1, afbeelding 1 van 3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: stap 1, afbeelding 2 van 3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: stap 1, afbeelding 3 van 3
      • Remove the air tank by rotating it counterclockwise.
      • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
      • The pressure gauge will indicate the leftover air in the gun.
      Vraag FixBot
      Voeg opmerking toe
    2. Smart Parts Ion Bolt Replacement: stap 2, afbeelding 1 van 2 Smart Parts Ion Bolt Replacement: stap 2, afbeelding 2 van 2
      • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
      Vraag FixBot
      Voeg opmerking toe
    1. Smart Parts Ion Bolt Replacement, Smart Parts Ion De-Gassing: stap 3, afbeelding 1 van 1
      • Turn the gun on by pressing the power button until the red light blinks.
      • Turn vision mode off by pressing the power button again.
      • Red light should be flashing in a double blink sequence.
      Vraag FixBot
      Voeg opmerking toe
    2. Smart Parts Ion Bolt Replacement: stap 4, afbeelding 1 van 1
      • Pull the trigger to release the air in the gun.
      • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
      Vraag FixBot
      Voeg opmerking toe
    1. Smart Parts Ion Bolt Replacement, Grip: stap 5, afbeelding 1 van 1
      • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Smart Parts Ion Bolt Replacement: stap 6, afbeelding 1 van 1
      • Remove the grip by sliding it towards the front of the gun.
      Vraag FixBot
      Voeg opmerking toe
    1. Smart Parts Ion Bolt Replacement, Battery: stap 7, afbeelding 1 van 2 Smart Parts Ion Bolt Replacement, Battery: stap 7, afbeelding 2 van 2
      • Remove the 9V battery by unsnapping it.
      Vraag FixBot
      Voeg opmerking toe
    1. Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: stap 8, afbeelding 1 van 3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: stap 8, afbeelding 2 van 3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: stap 8, afbeelding 3 van 3
      • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
      Vraag FixBot
      Voeg opmerking toe
    2. Smart Parts Ion Bolt Replacement: stap 9, afbeelding 1 van 2 Smart Parts Ion Bolt Replacement: stap 9, afbeelding 2 van 2
      • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
      Vraag FixBot
      Voeg opmerking toe
    3. Smart Parts Ion Bolt Replacement: stap 10, afbeelding 1 van 1
      • Separate the gun's body from the frame by gently pulling them in opposite directions.
      Vraag FixBot
      Voeg opmerking toe
    4. Smart Parts Ion Bolt Replacement: stap 11, afbeelding 1 van 1
      • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
      Vraag FixBot
      Voeg opmerking toe
    1. Smart Parts Ion Bolt Replacement, Removing the Solenoid from the Body: stap 12, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
      • Another small tool or your fingers will work for this.
      Vraag FixBot
      Voeg opmerking toe
    2. Smart Parts Ion Bolt Replacement: stap 13, afbeelding 1 van 1
      • Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
      Vraag FixBot
      Voeg opmerking toe
    3. Smart Parts Ion Bolt Replacement: stap 14, afbeelding 1 van 1
      • Separate the solenoid from the gun's body by gently pulling it upwards.
      Vraag FixBot
      Voeg opmerking toe
    4. Smart Parts Ion Bolt Replacement: stap 15, afbeelding 1 van 1
      • Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
      Vraag FixBot
      Voeg opmerking toe
    1. Smart Parts Ion Bolt Replacement, Bolt: stap 16, afbeelding 1 van 2 Smart Parts Ion Bolt Replacement, Bolt: stap 16, afbeelding 2 van 2
      • Separate the front body breach from the fire chamber by rotating the breach counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. Smart Parts Ion Bolt Replacement: stap 17, afbeelding 1 van 1
      • Remove the bolt from the front body breach by gently pulling on the bolt.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Shane Villalpando
1.043 Reputatie
10 handleidingen geschreven
Cal Poly, Team 8-42, Amido Winter 2015 Lid van Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 3,262
