Ga door naar hoofdinhoud
Skytex Skypad Alpha 2 Battery Replacement
Wat je nodig hebt
  1. Skytex Skypad Alpha 2 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Battery Replacement: stap 2, afbeelding 1 van 2 Skytex Skypad Alpha 2 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Battery Replacement: stap 4, afbeelding 1 van 1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove soldered connections to separate the battery wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on motherboard.
    • Following the red and black wires, that come out of the battery, to their respective connections on the motherboard will indicate where to solder.
    • Follow link for further soldering information: How to Solder and Desolder Connections
  6. Skytex Skypad Alpha 2 Battery Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to remove battery from tablet.
    • Be sure to remove the battery carefully to avoid damage. Damage of battery can release harmful chemicals and may cause a fire.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rebecca Ramirez
481 Reputatie
3 handleidingen geschreven
Baylor, Team 6-5, Williams Fall 2015 Lid van Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Leden
8 handleidingen geschreven
Één opmerking
Excellent Guide
Problem is where to obtain the Replacement battery ???
J P SULLIVAN - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 808
