Ga door naar hoofdinhoud
Skytex Skypad Alpha 2 Antenna Replacement
Wat je nodig hebt
  1. Skytex Skypad Alpha 2 Antenna Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Antenna Replacement: stap 2, afbeelding 1 van 2 Skytex Skypad Alpha 2 Antenna Replacement: stap 2, afbeelding 2 van 2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Antenna Replacement: stap 3, afbeelding 1 van 1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Antenna Replacement: stap 4, afbeelding 1 van 1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Antenna Replacement, Antenna: stap 5, afbeelding 1 van 1
    • Remove the metallic electrical tape, just enough, to allow the antenna to hang freely.
    • Remove all black and yellow tape, if necessary, on the motherboard.
  6. Skytex Skypad Alpha 2 Antenna Replacement: stap 6, afbeelding 1 van 1
    • Remove the soldered connections to separate the antenna wire from the motherboard.
    • The antenna wire will be connected to the motherboard with 2 connections, so be sure to remove both with the soldering iron.
    • Follow the link below for further soldering information: How To Solder and Desolder Connections.
    • Soldering irons require a large amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
  7. Skytex Skypad Alpha 2 Antenna Replacement: stap 7, afbeelding 1 van 1
    • Remove the antenna from the tablet using a pair of tweezers.
    • The antenna is actually fastened inside the back case of the tablet, pull gently to free it from the adhesive.
Conclusie
Rebecca Ramirez
481 Reputatie
3 handleidingen geschreven
Baylor, Team 6-5, Williams Fall 2015 Lid van Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 137
