Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
Find the wires connected to the speaker and check if they are intact.
If a wire is broken, use a soldering iron to reattach it to the speaker.
To learn how to solder, read the Hoe moet je (de-)solderen? Guide.
After soldering is complete, the wires should look like this.
Één opmerking
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
