Inleiding
Replace your LCD display only as a last option. Since the LCD display uses a flexible flat cable(FFC), improperly inserting the cable may cause damage to your device.
Wat je nodig hebt
From the back of the device, slide the back panel downwards to unlock the panel.
Lift the panel up, exposing the battery.
Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
Één andere persoon heeft deze handleiding voltooid.
