Ga door naar hoofdinhoud
Singer Simple Sewing Machine (Model 2263) Needle Replacement
Wat je nodig hebt
  1. Singer Simple Sewing Machine (Model 2263) Needle Replacement, Needle: stap 1, afbeelding 1 van 1
    • Turn off the sewing machine and unplug it.
    Vraag FixBot
    Voeg opmerking toe
  2. Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 2, afbeelding 1 van 1
    • Push the back lever up and remove the presser foot.
    Vraag FixBot
    Voeg opmerking toe
  3. Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 3, afbeelding 1 van 1
    • Raise the needle bar by turning the handwheel toward you.
    Vraag FixBot
    Voeg opmerking toe
  4. Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 4, afbeelding 1 van 1
    • With the provided Singer screwdriver or a flat-head screwdriver, loosen the clamp screw by turning it toward you.
    Vraag FixBot
    Voeg opmerking toe
  5. Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 5, afbeelding 1 van 1
    • Remove the broken needle.
    Vraag FixBot
    Voeg opmerking toe
  6. Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 6, afbeelding 1 van 2 Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 6, afbeelding 2 van 2
    • Insert the new needle with the flat side (the side with the numbers) facing the back of the sewing machine. Tighten the clamp screw by turning it toward the back.
    Vraag FixBot
    Voeg opmerking toe
  7. Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 7, afbeelding 1 van 2 Singer Simple Sewing Machine (Model 2263) Needle Replacement: stap 7, afbeelding 2 van 2
    • Put the presser foot back on by pushing the back lever up and guiding the bar on the presser foot onto the hook of the needle bar. Release the lever to secure.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Once the pressure foot is attached, thread the needle before plugging in the sewing machine and turning it on.
Renee Allred
145 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Please assist me with adjusting needle bar height for Singer Simple 2263 cannot find how to adjust hook timing either have watched sooo many videos none have helped me
Maria L. Soto - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 147
Altijd: 1,886
