Ga door naar hoofdinhoud
Siemens A56 Keyboard Replacement
    1. Siemens A56 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Press down on the grooved area firmly in the direction of arrow #1.
      • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
      • Photos taken from: http://theinformr.com/uploads/manuals/si...
      Vraag FixBot
      Voeg opmerking toe
    2. Siemens A56 Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Turn off the phone before removing the battery to avoid damage.
      • Press the latch on the battery in the direction of arrow #3.
      • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
      • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Siemens A56 Keyboard Replacement, Front Plate: stap 3, afbeelding 1 van 3 Siemens A56 Keyboard Replacement, Front Plate: stap 3, afbeelding 2 van 3 Siemens A56 Keyboard Replacement, Front Plate: stap 3, afbeelding 3 van 3
      • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
      • Pull up on the two plastic clips at the top of the phone.
      • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Siemens A56 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 3 Siemens A56 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 3 Siemens A56 Keyboard Replacement, Keyboard: stap 4, afbeelding 3 van 3
      • The keyboard can be easily removed by hand.
      • Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Andrew Corriveau
97 Reputatie
1 Handleiding geschreven
Clemson, Team 6-6, Benson Spring 2014 Lid van Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Leden
36 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 36
Altijd: 641
