Ga door naar hoofdinhoud
Sidekick II Keyboard Replacement
Wat je nodig hebt
  1. Sidekick II Keyboard Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
    Vraag FixBot
    Voeg opmerking toe
  2. Sidekick II Keyboard Replacement: stap 2, afbeelding 1 van 2 Sidekick II Keyboard Replacement: stap 2, afbeelding 2 van 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    Vraag FixBot
    Voeg opmerking toe
  3. Sidekick II Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    Vraag FixBot
    Voeg opmerking toe
  4. Sidekick II Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
    Vraag FixBot
    Voeg opmerking toe
  5. Sidekick II Keyboard Replacement: stap 5, afbeelding 1 van 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
    Vraag FixBot
    Voeg opmerking toe
  6. Sidekick II Keyboard Replacement, Keyboard: stap 6, afbeelding 1 van 2 Sidekick II Keyboard Replacement, Keyboard: stap 6, afbeelding 2 van 2
    • Remove screen from case
    Vraag FixBot
    Voeg opmerking toe
  7. Sidekick II Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove both black "rivets" from the back of the case with the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  8. Sidekick II Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Push keyboard out of the front of the casing with your thumbs.
    • Make sure not to press too hard; you may break the board.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
michael albaum
108 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-19, Maness Winter 2010 Lid van Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 2,430
