Ga door naar hoofdinhoud
Side Panel Removal
Wat je nodig hebt
  1. Side Panel Removal, Side Panel Removal: stap 1, afbeelding 1 van 3 Side Panel Removal, Side Panel Removal: stap 1, afbeelding 2 van 3 Side Panel Removal, Side Panel Removal: stap 1, afbeelding 3 van 3
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
    Vraag FixBot
    Voeg opmerking toe
  2. Side Panel Removal: stap 2, afbeelding 1 van 3 Side Panel Removal: stap 2, afbeelding 2 van 3 Side Panel Removal: stap 2, afbeelding 3 van 3
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Oli
1.577 Reputatie
4 handleidingen geschreven
1Gids Commentaar
I took it out, but now it’s not going all the way in
Ali - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 91
Altijd: 3,724
