Ga door naar hoofdinhoud
Sharp Aquos Crystal USB Port Replacement
Wat je nodig hebt
    1. Sharp Aquos Crystal USB Port Replacement, Back Panel: stap 1, afbeelding 1 van 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: stap 1, afbeelding 2 van 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: stap 1, afbeelding 3 van 3
      • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
      Vraag FixBot
      Voeg opmerking toe
    1. Sharp Aquos Crystal USB Port Replacement, USB Port: stap 2, afbeelding 1 van 2 Sharp Aquos Crystal USB Port Replacement, USB Port: stap 2, afbeelding 2 van 2
      • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
      • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Sharp Aquos Crystal USB Port Replacement: stap 3, afbeelding 1 van 2 Sharp Aquos Crystal USB Port Replacement: stap 3, afbeelding 2 van 2
      • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
      Vraag FixBot
      Voeg opmerking toe
    3. Sharp Aquos Crystal USB Port Replacement: stap 4, afbeelding 1 van 2 Sharp Aquos Crystal USB Port Replacement: stap 4, afbeelding 2 van 2
      • Disconnect the wire by lifting it up with a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    4. Sharp Aquos Crystal USB Port Replacement: stap 5, afbeelding 1 van 3 Sharp Aquos Crystal USB Port Replacement: stap 5, afbeelding 2 van 3 Sharp Aquos Crystal USB Port Replacement: stap 5, afbeelding 3 van 3
      • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
      Vraag FixBot
      Voeg opmerking toe
    5. Sharp Aquos Crystal USB Port Replacement: stap 6, afbeelding 1 van 1
      • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Felicia Imbriano
1.266 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 7-4, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-4, Catania Spring 2016
UMASSD-CATANIA-S16S7G4
3 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 3,055
