Ga door naar hoofdinhoud
Sharp Aquos Crystal Battery Replacement
Wat je nodig hebt
  1. Sharp Aquos Crystal Battery Replacement, Back Panel: stap 1, afbeelding 1 van 3 Sharp Aquos Crystal Battery Replacement, Back Panel: stap 1, afbeelding 2 van 3 Sharp Aquos Crystal Battery Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    Sense4liteなんですけど全く取れないです
    kpt - Antwoord
    Helo my back camera problem please Oder my camera
    Umar Umar - Antwoord
  2. Sharp Aquos Crystal Battery Replacement, USB Port: stap 2, afbeelding 1 van 2 Sharp Aquos Crystal Battery Replacement, USB Port: stap 2, afbeelding 2 van 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Battery Replacement: stap 3, afbeelding 1 van 2 Sharp Aquos Crystal Battery Replacement: stap 3, afbeelding 2 van 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Battery Replacement: stap 4, afbeelding 1 van 2 Sharp Aquos Crystal Battery Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
    what does the wire go to
    Aven Myers - Antwoord
  5. Sharp Aquos Crystal Battery Replacement: stap 5, afbeelding 1 van 3 Sharp Aquos Crystal Battery Replacement: stap 5, afbeelding 2 van 3 Sharp Aquos Crystal Battery Replacement: stap 5, afbeelding 3 van 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Battery Replacement: stap 6, afbeelding 1 van 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    Hello
    I would like to buy a Sharp c10 Aquos Crystal USB Port
    Can you help me with that ???
    ابو مصطفى - Antwoord
    I need this part (aquos r2) I'm from Pakistan
    Faisal Abbas - Antwoord
  7. Sharp Aquos Crystal Battery Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Battery Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Battery Replacement: stap 9, afbeelding 1 van 2 Sharp Aquos Crystal Battery Replacement: stap 9, afbeelding 2 van 2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Battery Replacement: stap 10, afbeelding 1 van 1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Battery Replacement: stap 11, afbeelding 1 van 1
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Battery Replacement, Battery: stap 12, afbeelding 1 van 1
    • Peel off the tape holding the battery down.
  13. Sharp Aquos Crystal Battery Replacement: stap 13, afbeelding 1 van 2 Sharp Aquos Crystal Battery Replacement: stap 13, afbeelding 2 van 2
    • Lift the battery out with your hands.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Felicia Imbriano
1.230 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 7-4, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-4, Catania Spring 2016
UMASSD-CATANIA-S16S7G4
3 Leden
24 handleidingen geschreven
3 opmerkingen
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
jeanpaolo lin - Antwoord
hello, where can I buy this battery ? thanks, Ari
ari leon Kolbar - Antwoord
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
Masood Ali - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 59
Afgelopen 30 dagen: 192
Altijd: 17,151
