Inleiding
If your phone is not turning on or charging, you may need a new battery.
This guide will show you how to open your device and remove the inside motherboard to replace your battery.
Wat je nodig hebt
Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
9 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
hello, where can I buy this battery ? thanks, Ari
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
