Inleiding
Does your vacuum fail to pick up particles on your floor? If so, this guide outlines how to remove the two vacuum tubes on the Shark Rocket Professional. While reading this guide, you will also learn how to unclog your vacuum to improve suction.
Wat je nodig hebt
Look at the Shark Rocket Professional's Extension Rod.
Identify where the hose connects to the main body of the vacuum.
Press the tabs on the sides of the connector to remove the hose.
4Gids Commentaar
Thank you for this, this guide helped a ton.
