Ga door naar hoofdinhoud
Shark Rocket HV301 Hose Replacement
Wat je nodig hebt
    1. Shark Rocket HV301 Hose Replacement, Hose: stap 1, afbeelding 1 van 3 Shark Rocket HV301 Hose Replacement, Hose: stap 1, afbeelding 2 van 3 Shark Rocket HV301 Hose Replacement, Hose: stap 1, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      T4 Torx Screwdriver
      $5.49
      • Place the base of the vacuum face down so the roller brush is facing you.
      • Locate the five screws and remove the screws using a Phillips #1 screwdriver. On some models, the screws may be Torx T4 instead of Phillips.
      • On some models, you may need to remove the two screws next to the big wheels, under the top two circled screws in the picture, with a Torx T3 screwdriver.
      • You may want to disconnect the base from the stick of the vacuum to make it easier to move around.
      Vraag FixBot
      Voeg opmerking toe
    2. Shark Rocket HV301 Hose Replacement: stap 2, afbeelding 1 van 2 Shark Rocket HV301 Hose Replacement: stap 2, afbeelding 2 van 2
      • Locate and remove the two small wheels below the roller brush by prying with a plastic prying tool.
      • This may require some force.
      Vraag FixBot
      Voeg opmerking toe
    3. Shark Rocket HV301 Hose Replacement: stap 3, afbeelding 1 van 3 Shark Rocket HV301 Hose Replacement: stap 3, afbeelding 2 van 3 Shark Rocket HV301 Hose Replacement: stap 3, afbeelding 3 van 3
      T4 Torx Screwdriver
      $5.49
      • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
      • Pull up on the plate covering the roller brush and remove it.
      • On some models, you may need to remove 3 additional screws under the roller brush cover with a Torx T4 screwdriver. (Not pictured.)
      Vraag FixBot
      Voeg opmerking toe
    4. Shark Rocket HV301 Hose Replacement: stap 4, afbeelding 1 van 3 Shark Rocket HV301 Hose Replacement: stap 4, afbeelding 2 van 3 Shark Rocket HV301 Hose Replacement: stap 4, afbeelding 3 van 3
      iFixit Opening Picks (Set of 6)
      $4.95
      • Turn the vacuum over so the roller brush is on the ground.
      • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
      • It may help to slip opening picks in the edge between the gray cover and the orange and clear base sections.
      Vraag FixBot
      Voeg opmerking toe
    5. Shark Rocket HV301 Hose Replacement: stap 5, afbeelding 1 van 3 Shark Rocket HV301 Hose Replacement: stap 5, afbeelding 2 van 3 Shark Rocket HV301 Hose Replacement: stap 5, afbeelding 3 van 3
      • Gently pinch head of cable and pull upwards until upper casing disconnects from vacuum and proceed with removing upper casing.
      • Return the vacuum to its original position with the roller brush facing you.
      • Locate the screw to the right of the vacuum hose, close to the right wheel, and remove the screw with a Phillips #2 screwdriver.
      • Note: some models may not include this screw.
      Vraag FixBot
      Voeg opmerking toe
    6. Shark Rocket HV301 Hose Replacement: stap 6, afbeelding 1 van 3 Shark Rocket HV301 Hose Replacement: stap 6, afbeelding 2 van 3 Shark Rocket HV301 Hose Replacement: stap 6, afbeelding 3 van 3
      • Pull on the dark gray end of the hose that attaches to the roller brush chamber to remove the hose from the base.
      • Unscrew the hose from the dark gray end by twisting it clockwise.
      • Unscrew the hose out of the chamber that attaches the stick to the base by twisting it clockwise. The hose is glued into the chamber, so this may require some force.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
35 andere personen hebben deze handleiding voltooid.
Shelby Baccala
847 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-5, Livingston Fall 2016 Lid van Cal Poly, Team 10-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G5
4 Leden
21 handleidingen geschreven
62Gids Commentaar
Great instructions, now where do I get the replacement hose. I can't seem to find one anywhere, please tell be where to look
Kay Fisher - Antwoord Deel
Rob the hose from the hard floor attachment, you probably do not use it as at low speed the brush head is awesome on hard floors.
Suzannne Scheans - Antwoord Deel
I found a hose that is a perfect fit. EVERBILT 6 ft Bilge and Pump Discharge Hose. 1-1/8 inch ID. Got it at Home Depot.
Nick Verciglio - Antwoord Deel
How did you get the hose from Home Depot to work? I’d like to try it, and I was hoping you would give some advice.
Joey Griffin - Antwoord Deel
Thank you so much for this recommendation! The Everbilt Bilge and Pump hose works perfectly!!! And now I have back up if I need to replace it again.
Thank you for the instructions as well Shelby! So much better than spending another $50 on a replacement head!
irishernie - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 278
Altijd: 94,378
