Ga door naar hoofdinhoud
Shark Navigator Lightweight Upright Motor Replacement
Wat je nodig hebt
    1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: stap 1, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: stap 1, afbeelding 2 van 2
      • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
      Vraag FixBot
      Voeg opmerking toe
    2. Shark Navigator Lightweight Upright Motor Replacement: stap 2, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 2, afbeelding 2 van 2
      • Lay the vacuum on its side.
      • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
      Vraag FixBot
      Voeg opmerking toe
    3. Shark Navigator Lightweight Upright Motor Replacement: stap 3, afbeelding 1 van 1
      • Flip over the vacuum head so the brush head is facing up.
      Vraag FixBot
      Voeg opmerking toe
    4. Shark Navigator Lightweight Upright Motor Replacement: stap 4, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 4, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 4, afbeelding 3 van 3
      • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
      • Repeat this for the other wheel.
      Vraag FixBot
      Voeg opmerking toe
    5. Shark Navigator Lightweight Upright Motor Replacement: stap 5, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 5, afbeelding 2 van 2
      • Remove the two 18mm screws with a JIS 1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. Shark Navigator Lightweight Upright Motor Replacement: stap 6, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 6, afbeelding 2 van 2
      • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. Shark Navigator Lightweight Upright Motor Replacement: stap 7, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 7, afbeelding 2 van 2
      • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    8. Shark Navigator Lightweight Upright Motor Replacement: stap 8, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 8, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 8, afbeelding 3 van 3
      • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
      • Prying in multiple locations may be necessary to create separation.
      Vraag FixBot
      Voeg opmerking toe
    1. Shark Navigator Lightweight Upright Motor Replacement, Motor: stap 9, afbeelding 1 van 1
      • Locate the motor on the top right corner of the vacuum head shell.
      Vraag FixBot
      Voeg opmerking toe
    2. Shark Navigator Lightweight Upright Motor Replacement: stap 10, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 10, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 10, afbeelding 3 van 3
      • Remove the belt from the motor gear by sliding the belt to the right.
      Vraag FixBot
      Voeg opmerking toe
    3. Shark Navigator Lightweight Upright Motor Replacement: stap 11, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 11, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motor Replacement: stap 11, afbeelding 3 van 3
      • Remove the white metal wire connector from the motor.
      • The white cable is positive.
      Vraag FixBot
      Voeg opmerking toe
    4. Shark Navigator Lightweight Upright Motor Replacement: stap 12, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motor Replacement: stap 12, afbeelding 2 van 2
      • Remove the black metal wire connector from the motor.
      • The black cable is negative.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Suzie
545 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G6, Livingston Fall 2017 Lid van Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Leden
18 handleidingen geschreven
2Gids Commentaar
Where does one buy the replacement motor?
Michael De La Rosa - Antwoord Deel
Where can I get spares??
ck
Clive Kingscote - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 47
Altijd: 10,585
