Ga door naar hoofdinhoud
Shark Navigator Lightweight Upright Motherboard Replacement
Wat je nodig hebt
  1. Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: stap 1, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: stap 1, afbeelding 2 van 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motherboard Replacement: stap 2, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motherboard Replacement: stap 4, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 4, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motherboard Replacement: stap 5, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motherboard Replacement: stap 6, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motherboard Replacement: stap 7, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motherboard Replacement: stap 8, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 8, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motherboard Replacement, Motor: stap 9, afbeelding 1 van 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motherboard Replacement: stap 10, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 10, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motherboard Replacement: stap 11, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 11, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motherboard Replacement: stap 12, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
  13. Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: stap 13, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: stap 13, afbeelding 2 van 2
    • Remove the two 12mm screws using a JIS 1 screwdriver.
  14. Shark Navigator Lightweight Upright Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the wire housing by removing one 12mm screw using a JIS 1 screwdriver.
  15. Shark Navigator Lightweight Upright Motherboard Replacement: stap 15, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift up the wire housing from the plastic base using tweezers.
  16. Shark Navigator Lightweight Upright Motherboard Replacement: stap 16, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Free the black and white cables that were previously attached to the motor from their slot.
  17. Shark Navigator Lightweight Upright Motherboard Replacement: stap 17, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Free the motherboard and its connecting parts from the rest of the vacuum.
    • Turn the motherboard upside-down and spread wires out.
  18. Shark Navigator Lightweight Upright Motherboard Replacement: stap 18, afbeelding 1 van 2 Shark Navigator Lightweight Upright Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Heat the wire connection's solder joint until the joint looks wet and liquidy.
    • While maintaining contact with the solder iron, free the wire end by pulling the wire away from the board with the tweezers.
    • For instructions on how to solder properly please refer to this soldering technique guide. Hoe moet je (de-)solderen?
    • Remember which cables were soldered onto where. You will have to re-solder the cables back onto the same joint.
    • Solder iron is extremely hot and should be handled with care. Always wear eye protection when soldering.
  19. Shark Navigator Lightweight Upright Motherboard Replacement: stap 19, afbeelding 1 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 19, afbeelding 2 van 3 Shark Navigator Lightweight Upright Motherboard Replacement: stap 19, afbeelding 3 van 3
    • Completely free the cable by pulling it out of the board.
    • Repeat for the remaining cables. There are 4 total.
Conclusie
Suzie
527 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G6, Livingston Fall 2017 Lid van Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 1,566
