Ga door naar hoofdinhoud
Shark NV352 Motherboard Replacement
Wat je nodig hebt
  1. Shark NV352 Motherboard Replacement, Roller Brush: stap 1, afbeelding 1 van 2 Shark NV352 Motherboard Replacement, Roller Brush: stap 1, afbeelding 2 van 2
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Motherboard Replacement: stap 3, afbeelding 1 van 2 Shark NV352 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Motherboard Replacement: stap 4, afbeelding 1 van 2 Shark NV352 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Motherboard Replacement: stap 5, afbeelding 1 van 2 Shark NV352 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Motherboard Replacement: stap 6, afbeelding 1 van 2 Shark NV352 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Take out the roller brush by lifting it out of its tray.
  9. Shark NV352 Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • The capacitors on the motherboard may still hold a residual charge, so avoid touching them because there is a risk of getting shocked.
    • Remove the motherboard carefully so you don't cause damage by pulling the wires connected to it.
    • Lift the motherboard out of the plastic tray to remove it.
  10. Shark NV352 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the wires connecting the motherboard to the vacuum by unscrewing the twist-on wire connectors.
    • Desolder the wires connecting the motherboard to the motor. Get tips on how to desolder by checking out How to Solder and Desolder.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Wesley T Benica
378 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G5, Forte Fall 2017 Lid van Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Leden
10 handleidingen geschreven
5 opmerkingen
Great work team!
Thomas Smith - Antwoord
Thanks Thomas! Your support is greatly appreciated!
Vincent Leuzze -
Any knowledge on how to fix or replace the handle lick button. Mine won't lock and so the whole vacuum doesn't work
Jana Butler - Antwoord
I have a 350 will the 352 powerhead motherboard work as a replacement as I can’t find a 305 one
chaseraymond - Antwoord
I have a 350 vacume but need a replacement powerhead circuit board would the 352 work? It looks the same and it’s the same unit?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 1,530
