Ga door naar hoofdinhoud
Shark Matrix RV2310 Wheel Assembly Replacement
Wat je nodig hebt
    1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: stap 1, afbeelding 1 van 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: stap 1, afbeelding 2 van 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: stap 1, afbeelding 3 van 3
      • Remove the two 11 mm Phillips screws holding the battery plate in place.
      • Remove the battery plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Shark Matrix RV2310 Wheel Assembly Replacement: stap 2, afbeelding 1 van 3 Shark Matrix RV2310 Wheel Assembly Replacement: stap 2, afbeelding 2 van 3 Shark Matrix RV2310 Wheel Assembly Replacement: stap 2, afbeelding 3 van 3
      • Remove the battery from the compartment.
      • Disconnect the electrical cable connection from the battery to the robot.
      Vraag FixBot
      Voeg opmerking toe
    1. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: stap 3, afbeelding 1 van 2 Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: stap 3, afbeelding 2 van 2
      • Remove the five 11 mm Phillips screws holding the wheel assembly in place.
      • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
      Vraag FixBot
      Voeg opmerking toe
    2. Shark Matrix RV2310 Wheel Assembly Replacement: stap 4, afbeelding 1 van 1
      • Lift the wheel assembly out of the vacuum.
      • Do not pull or tug too hard on the wheel when lifting it, as there is a wire connection between the wheel and the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Shark Matrix RV2310 Wheel Assembly Replacement: stap 5, afbeelding 1 van 1
      • Undo the wire connection between the motherboard and the wheel assembly by gently pulling the wire out from the wheel assembly's connector.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Joshua Correia
697 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-4, Botvin Spring 2024 Lid van UMass Dartmouth, Team 6-4, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G4
2 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 108
Altijd: 1,161
