Ga door naar hoofdinhoud
Shark ION Robot R75 Drive Wheel Assembly Replacement
Wat je nodig hebt
    1. Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: stap 1, afbeelding 1 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: stap 1, afbeelding 2 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: stap 1, afbeelding 3 van 3
      • Make sure the robot is shut off by pressing the power button on top.
      • Flip the R75 over so that the underside is facing up.
      • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
      • Remove the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 2, afbeelding 1 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 2, afbeelding 2 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 2, afbeelding 3 van 3
      • Be careful when removing the battery, as it will still be connected to a wire.
      • Slowly pull the white tabs outward to remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 3, afbeelding 1 van 2 Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Be careful when removing the connector, as the part can break if too much force is used.
      • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
      • Remove the battery from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Shark ION Robot R75 Drive Wheel Assembly Replacement, Drive Wheel Assembly: stap 4, afbeelding 1 van 1
      • Flip the R75 to its underside.
      • Make sure the R75 is shut off.
      • For extra security, disconnect the battery by following the prerequisite guide.
      Vraag FixBot
      Voeg opmerking toe
    2. Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 5, afbeelding 1 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 5, afbeelding 2 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 5, afbeelding 3 van 3
      • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
      • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
      • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
      Vraag FixBot
      Voeg opmerking toe
    3. Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 6, afbeelding 1 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 6, afbeelding 2 van 3 Shark ION Robot R75 Drive Wheel Assembly Replacement: stap 6, afbeelding 3 van 3
      • Flip the wheel assembly over and disconnect the cable connector on its underside.
      • Remove the drive wheel assembly.
      • Repeat this process for the other side if necessary.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
Where I can buy the Shark ION Robot R75 Drive Wheel Assembly Replacement?
Thanks for your help!
xoxolo - Antwoord Deel
Do you know what the drive wheel motor cable is (see Step 6)? It's a 6 pin to 5 pin and the grooves are on the thin side and pitch of ~1.4mm. Possible a JST ZH?
Seth T - Antwoord Deel
I appreciate the step-by-step instructions with pictures... this was very helpful. However, my rv750 doesn't have the screws by the wheel assembly.
I've removed the screws, but it appears that I will need to separate the bottom from the top to access the wheel assemblies. Do you have a step=by step for the rv750 that has the wheel assembly enclosed?
RandiB - Antwoord Deel
The right wheel ass has a small gear striped inside, can you buy the small gears to repair the wheel drive?
Jerry Rotenberry - Antwoord Deel
I'm going to try these from Walmart
https://www.walmart.com/ip/5Pcs-set-Inte...
Miles Morgan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 36
Altijd: 10,848
