Inleiding
This guide for Shark AI Ultra AV2511AE is going to show the steps to replace the side brush motor on the smart vacuum. This will be relevant when the side brushes are not spinning and pushing trash successfully toward the main roller brush on the smart vacuum.
Wat je nodig hebt
Orient the device upside-down
Remove two 15 mm screws using a Phillips #1 screwdriver.
Remove the battery cover.
Remove the debris container.
Remove the main brush cover from the vacuum to expose the roller.
